Printed IFA trace width?
Hello! I'm trying to design a printed Inverted F Antenna for the GSM900 band. I managed to select lengths of traces which make up the antenna elements (the feed line, the folded part of the unipole, and the short-circuit stub) for resonance at 925MHz.
Now I'd like to further optimize the antenna, so my question is, how do you choose the optimal width of those traces? I have calculated that the microstrip line matched to Z0 of 50 Ohms on my substrate needs to be 3mm wide. But the antenna structure (including the final section of the feed line) has no ground plane under it, so obviously the optimal widths are different, but I don't know how to select them. Any advice? Thanks!
RE: Printed IFA trace width?
Only very expensive computer programs can get you all the details you need.
Get a VSWR test setup going.
Pick a dimension line width that's easy to build and start changing the PIFA dimensions while looking at VSWR.
Those antennas can be a bit sensitive. Your results change with the size of your groundplane since the PIFA structure actually isn't an antenna, it's a tuning mechanism to get your ground plane to radiate efficiently. If you're doing some empirical VSWR tuning, in addition to the PIFA dimensions, have some metal tape to change your ground plane length to see the effects.
kch
I've assumed that when you look at the antenna as a resonant circuit, the path from the feed-point back to ground is an inductive loop, and the stem is a capacitor. If you want the Q high on a resonant circuit, get rid of resistance. For the F antenna, make the inductive trace wide.
Higgler is right, without simulation software, you can only guess, or cut-and-try (if you've got a network analyzer). But, Ansoft Designer SV (Student Version) is too limited to do a IFA antenna - I've tried. The real version would keep some manager from having a company car, so most engineers have to do without.
