Spline class for ANSI B92.1
This post was moved over to this forum at the recommendation of Kenat.
I'm looking thru the ANSI B92.1 spline book (table #3) and trying to find out if the profile tolerance needs to be compensated as the tooth thickness or space width. I believe that the book reads that the multiplication factor only applies to the CTT or CSW. Can anybody confirm this? I also need the Para number and page if possible.
Thanks to all.
Thanks to all.
RE: Spline class for ANSI B92.1
The profile & lead errors contribute to the effective fit of a spline set, when comparing actual and effective tooth/space sizes.
