NC Block output difference
Hi All
Is there any difference in the blocks
G94 G17 G81 X Y Z F
and
G17 G81 G94 X Y Z F
does both blocks gives same output..?
RE: NC Block output difference
Those blocks should produce the same results.
Ben Loosli
It depends on the machine control.
Most controls do not care what order the blocks are in.  Some "older" controls are very picky about the order.
In post builder you can change the order from the Word sequencing page.  Just drag and drop the blocks in the order you need.
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
www.myigetit.com
