B31.3 Software
B31.3 Software
Does anyone have suggestions on good software that will run shell, connections, etc.. calculations per the B31.3 rules? I am seriously considering Compress for Vessel calculations per ASME VIII-1 & VIII-2, but also need to consider piping and piping components.
RE: B31.3 Software
There are a lot of excellent software products available - the good software follows the requirements of various Codes (USA and other Country's requirements are included). GENERALLY speaking you will be able to buy software for structural analyses of piping and you will be able to buy software for structural analyses of pressure vessels. Some software companies offer both (piping and vessel) types of software.
Some vessel software follows the requirements of the ASME B&PV Code, Section VIII, Division 1 (design by rule). Most piping software follows the requirements of the ASME B31 Codes for Pressure Piping and they use beam theory for the analysis solution (you will sometimes have to supplement this with finite element analysis (FEA) of individual local component stresses).
Leonard Thill will likely answer this question by referring you to Paulin Research Group so I will beat him to the punch (sorry Leonard <grin>).
www.paulin.com
www.fepipe.com
www.prg-software.com
However I will refrain from listing ALL the providers of piping and vessel software because everybody has their favorite product. You will have to do some "homework" and look at all the products available and decide which are the best fit for your needs and budget.
Let the posting of opinions begin.
Regards, John.
RE: B31.3 Software
If you are talking about wall thickness calcs and branch reinforcement calcs then why not develop a spreadsheet to follow the particular Code rules. This will only take you a short time to do and you will also become more familiar with the Codal requirements.
RE: B31.3 Software
No John, I was wating for to reply.
If you want to work with the Bechtel, Jacobs and other EPC
for Pressure Vessel Software CODEWARE COMPRESS www.codeware.com check out the user list
John (thank you)
Leonard Stephen Thill
RE: B31.3 Software
Upcoming Webinars:
Additional training http://paulin.com/webinar/Default.aspx
Paulin Research Group offers webinars that discuss various subjects of interest to piping and pressure vessel designers and engineers.
Easy Development of SIFs for Pipe Shoes, Saddles, and Other Supports Tuesday, June 24, 2008 9:00 AM
Modeling of API 661 Air Cooler Nozzle Connections Tuesday, July 08, 2008 9:00 AM
SIFs and Flexibilities for Bends with Pipe and Structural Attachments Tuesday, July 22, 2008
Thick Walled Expansion Joints: Increased Application Using the New TEMA Rules and 2007 ASME Division 2 Fatigue Guidelines Tuesday, August 05, 2008
L S THILL
RE: B31.3 Software
You might also want to consider asking your question in the Eng-Tips forum on piping and the Eng-Tips forum on pressure vessels.
John
