Concrete slab on grade design
3
How do we design the concrete slab on grade? What is the procedure? I know the wire mesh is only for crack control, and is not designed as tension reinforcement.
I would appreciate your response.
RE: Concrete slab on grade design
Woven wire fabric can be used for tension reinforcement and for transverse temperature and shrinkage reinforcement.  Merely design the correct area of wire per spacing of wire.
You want this book:
"Designing Floor Slabs on Grade", by Ringo & Anderson, Aberdeen Group Publication.
Here's a place that sells it:
http://www.ecampus.com/book/0924659750
There's also a good reference and design guide published by the Cement and Concrete Association of Australia "Industrial Floors and Pavements". It's simple to understand and easy to follow.
Cheers!
Looks like there is not an easy way to design it. Typically, we provide 4" or 5" thick concrete slab on grade on typical residential and commercial construction (minimum soil bearing value of 1500 psf).
Is there any free download materials on this? I would buy a book, however, I am afraid I do not have time to wait for it.
Hey Spats,
Thanks for posting the spreadsheet, very helpful!
knelli
spats,
Thank you very much. You are the great.
spats,
I have yet to check it out but it looks good.
