SAFE Detailer how to use METRIC rebar 10M,20M, etc.
I'm located in CANADA. When I use SAFE 8, I can display the design using metric rebar (10M, 15M, 20M etc.) But when I run the DETAILER its showing "d 32" I want to use the METRIC type rebar. Any idea how ?
Thank you,
gasma1975
Thank you,
gasma1975
RE: SAFE Detailer how to use METRIC rebar 10M,20M, etc.
Detailer will pick up the bars which you have defined in Design.
Hope it will help.
Zee
