Exporting into Word file (ends of each line dissapearing!)
Hello all,
When I export my MathCAD file into Word, the ends of each line mysteriously dissapears (for example, 500mm will become 500mn, the other half of the m dissapears) What could cause this and how I can fix it? Thanks!
RE: Exporting into Word file (ends of each line dissapearing!)
Is this font dependent?. I have had problems where built in fonts are not the same size as the display/print fonts so they don't fit the display/print space. [Arial was aparticular problem]
If it persists and is in V14 then report it on the V14 bug page of the Collaboratory (under Help -> User Forums)
Philip
