Line type question
Line type question
When indicating that two (or more) hole centers are aligned, is the extension line between them drawn as a centerline or a solid line? For example if three mounting holes on one side of an item are directly aligned with three others on the other side, what kind of line goes between them to indicate this?
Dan
Dan
RE: Line type question
Believe it if you need it or leave it if you dare. - Robert Hunter
Dave D.
www.qmsi.ca
V
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
Dan
KENAT, probably the least qualified checker you'll ever meet...
I've seen board drawings where a centerline was used instead of an extension line, and they just never looked right to my eye.
Our CAD system more or less does this by default.
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
www.profileservices.ca
