File Properties extracting with VBA
I want to extract my file properties to a spread sheet.  I found some code below, but I believe it needs some tweeking.  I am no programmer, that's for sure.  Can anyone take a crack at this thing, and make it work as a macro for excel?
SYMPTOM/PROBLEM
How do you extract the file properties for a Solid Edge file using VB
Automation API?
SOLUTION/WORKAROUND
All the file properties that are listed under the "File/Properties" dialog can
be extracted by a VB propgram or a VBA macro in a spreadsheet.    Just make sure
that your project has a reference to the type library called "Solid Edge File
Properties".  The sample code below can be modified to suit your needs:
Sub GetFileProps()
Dim objPropSets As PropertySets
Dim objProps As Properties
Dim objProp As Property
Set objPropSets = CreateObject("SolidEdge.FileProperties")
Call objPropSets.Open("c:\temp\Part1.par")
'For Each objProps In objPropSets
'    For Each objProp In objProps
'     Debug.Print objProps.Name, ": ", objProp.Name, " = ", objProp.Value
'    Next
'Next
Set objProps = objPropSets.Item("ProjectInformation")
    Debug.Print objProp.Name, " = ", objProp.Value
Next
Set objProps = objPropSets.Item("SummaryInformation")
Next
Set objProps = objPropSets.Item("MechanicalModeling")
Next
Set objProps = objPropSets.Item("Custom")
Next
End
End Sub
RE: File Properties extracting with VBA
There used to be pdf on customizing solid edge on the UGS web site but I can't locate it.
It was V15 but there was a section on how to get file properties, which hasn't really changed.
I have it somehere and will post later when I find it.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Sounds good. I could really use it.
Thanks.
Page 161 shows how to get all file properties.
If you get the properties one section at a time you need to be careful because some do not exist in certain file types. I think it's the MechanicalModeling property set that does not exist in a draft file.
I had this problem when I was learning and had to check the file type so that I didn't get an error.
bc.
Quadro FX4600.
Cool.  I'll keep that in mind.  My problem is that I 100% to vb programing or programming of any kind. Don't suppose anyone out there has already got an excel macro done up for this,eh?
I think I have a program that gets all models linked to a draft file and saves the result in a text file.
This would show you how to create a new file and add information to it.
If you think it may be of help I'll have a look and post it later.
The code is probably not the best but it does work, and like you I'm self-taught and not an expert, so that's my excuse.
bc.
Quadro FX4600.
Sweet, I'll take it. Any example/resource I can get will help, and I need alot of help.  On the Microsoft website there are a whack of tutorials for VB.  I've down loaded the express addition and have started trying to learn. Hopefully I start getting the hand of it soon.
