invalid handle index error on loading
I am running NX4 and am having a problem with an important part (I need to print the drawings out today!)
Problem is as follows:-
-Part opened successfully this morning, continued working on draughting.
- NX crashed following a routine save so I closed everything and restarted the computer.
- On restarting the computer NX started up successfully
- The part I had been working on produced the following error on attempting to load it -
'An invlaid handle index was found reading an OM file: probable corruption'
- Further investigation shows that other parts from the same directory will load successfully and attempting to load the same part on a different machine results in the same error.
All help gratefully appreciated!
Roland
RE: invalid handle index error on loading
The best hope to get this particular part file fixed is to get it our GTAC organization so that development might have a chance to fix the part file.  Otherwise, you will need to revert back to your last archived copy and start you last work session over.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Hi John,
Yes I have forwarded the part file to Teamcentre Engineering (our distributor) for them to have a look at it.
Roland
