Class 1 Division 1 motor connection
As a fan manufacturer our motors are hard bolted to the fan casing and there is very little movement. Must we use a flexible connection such as Crouse Hinds ECGJH flexible couplings?
I can't find no clear statement on the limitations of hard conduit pipe and motors in the NEC.
Or is just standard practice to always use a flexible coupling, regardless of motor mounting system?
Any thoughts much appreciated.
RE: Class 1 Division 1 motor connection
Many thanks.
