Stress Analysis?
Stress Analysis?
I am working at an oil refining company and considering about stress analysis on piping.
Could some explain to me how will I do about gap(1ea,20mm)between pipe line supports and structure after operating.
Operating Temperature : 600'c
Operating Pressure : 26kg/cm2
Piping Material : TP321
Piping Size : 20"
Is it possible to operate it to keep remaining gap?
Piping Size : 20"
RE: Stress Analysis?
You need to get a stress engineer on site.
1) Have you performed any high temperature piping stress analysis before this particular assignment ?
2) What is your "Code of Record" for this analysis ?
3) Which software package are you using ? Whic version and edition ? Is it a fully registered or purloined copy ?
4) 600C is very hot... will you be performing a detailed anaysis at thickness transitions ?
5) Do you have any integrally welded attachments to this piping ? If so do you have a methodolology established to deal with these ?
-MJC
L S THILL
