overvoltage capability of appliances/TV sets
How long would you expect an an appliance or electronic device like a TV or microwave to last due to a sustained overvoltage? I'm thinking of a steady-state voltage in the 2 to 2.5 times normal range.
Have the surge protective devices folks done any work in this area?
RE: overvoltage capability of appliances/TV sets
Keith Cress
In high school we used banks of 150 W lights at 173% voltage for lightning effects on stage. The lamps lasted for many minutes.
But I agree with itsmoked in principle.
Bill
"Why not the best?"
Jimmy Carter
I just found a reference to some work done by Hydro Quebec. They refer to common electrical appliances like TVs, VCRs, digital clocks, answering machines and microwave ovens.
Their summary states:
- for 1 cycle events, most of the appliances were not damaged at voltages less than 250 V (208% of 120 V).
- for 10 cycle and 100 cycle events, most equipment was not damaged at voltages less than 200 V (166% of 120 V).
I suspect the cabability that is being described is largely a function of the internal MOVs in the appliance tested.
Keith Cress
http://www.itic.org/archives/iticurv.pdf
Not sure how useful it would be for your general appliances though.
My experience is that most appliances do not have an MOV in them, bearing in mind that they are usually subjected to cost-reduction engineering.
Also, an MOV subjected to 2* rated voltage will blow up in spectacular fashion.
At 2* rated voltage the usual switcher power supply will definitely blow up in a cycle or maybe two.
In the olden days, when we used transformers and regulators, the damage would be confined to a blown fuse.
Ray.
