Anchor Bolt question: NDS Table 11E
Table 11E lists the embedment depth in concrete as "6.0 and greater." If the embedment depth is less than 6" (e.g. 4"), do you reduce the design value (Z) listed in the table? If the answer is yes, what is the reduction and where is it specified in the NDS?
Thanks!
Thanks!
RE: Anchor Bolt question: NDS Table 11E
