suspension design advise - track change value
I'm designing double wishbone suspension for small 2-seater and I need advise about geometry changes, especially track change.
I've made some measurments from CAD model:
(* lenght from roll center to outer/inner wheel center
** outer/inner wheel camber)
Body roll -> 0 deg
Wheel track -> 1507,8mm (753,9/753,9)*
Camber** -> 0 deg / 0 deg
Body roll -> 2deg
Wheel track -> 1507,1 (757,5/749,6)*
Camber -> +0,96 deg / -0,87 deg
Body roll -> 4deg
Wheel track -> 1504,8 (760,3/744,5)*
Camber -> +1,90 deg / -1,96 deg
My questions are:
Are this track and camber changes correct?
What is maximum recommended track change for a track-use car?
thanks in advance
ohv
Body roll -> 0 deg
Body roll -> 2deg
Body roll -> 4deg
My questions are:
thanks in advance
ohv
RE: suspension design advise - track change value
Goran
