Minimum Bend Radius
Minimum Bend Radius
Minimum Bend Radius
If I have some bends with the grain and some against the grain what is the minimum bend radius for 5052-H32 aluminum sheet that has a thickness of .125 inches?  I want to make sure that we have no cracks at all.
Thanks for your help.
RE: Minimum Bend Radius
From my experiences with 5052-H32, you want to stay around 2-3T.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
ASM Handbook, Volume 14B shows for AA 5052 H32 temper , a 2t bend radius for 0.125" thick sheet. I would start here.
