poisson ratio polyurethane moldings
Anyone know what poisson ratio value range I should be using for FEA purposes?  Cannot find on efunda, etc.
mil-m-24041c
RE: poisson ratio polyurethane moldings
Have you tried the raw material manufacturer. They should be the best source grade specific data.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Due to the creep behaviour of plastics, stress is heavily dependent on strain rate, so a value for Poisson's ratio is generally not specified. If you look at a typical plastic data sheet, you should see that some parameters are actually specified at a defined strain rate (e.g elongation before break is usually at 50mm/s - sometimes other rates are given.
As Pat suggested, talk to the material supplier and they should be able to help.
Cheers
Harry
I tried talking to the material manufacturer, but the part that I am analyzing was made in the early-mid 80's and the company is unable to locate and provide the material data sheets.
I understand the creep-rate effects for a constant load, but for a one-time impulse-loading situation it seems there should be a poisson's rtion value applicable for polyurethane.
It will probably be called an apparent Poison Ratio. That's what they do with e mod which is also prone to creep.
Bayer Materials or Lenxis or whatever they call themselves now should have data on a similar grade. 20 years ago they literally published truck loads of technical data.
They invented PU and were always considered the market leader re technical service.
Do you have a website or phone # for Lenxis?
Was the "whatever they call themselves now" a clue.
That's Lanxess, used to be Bayer.
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
