minimum size of drilled shaft
can anyone tell me the minimum size of a drilled shaft? Thanks.
RE: minimum size of drilled shaft
(sorry)
For drilled piers or auger cast piling, micro piling, etc. the minimum size probably depends upon what is available from your local drillers.
Well drillers can go to 4" I think.
Bored piles with bentonitic mud : 24" ( because of the size of the kelly bar )
In Colorado I have seen thousand of residential projects with shafts of 8", 10" and 12". A lot of care is needed to construct these.
I have seen them down to 12"
Dik
30" min, 36" for the larger people. Reference FHWA - Drilled Shafts.
