Insert a shaft in a shaft w/hole perperdicular
(using the assembly constraints)How do you insert a shaft in another shaft that has a hole running perpendicular to the axis? When you put a hole in the second shaft perpendicular to the axis it is not recognized as a hole.
RE: Insert a shaft in a shaft w/hole perperdicular
There are many ways to do this.
Constrain pin line/line with the perpendicular hole
Constrain the end of the pin line/plane with the centerline/axis of the shaft and enter a distance that puts the pin in as far as you require it.
I use this for inserting cotter pins in shafts for example
Regards Adrian
