Question about editing feature parameter annotation
Okay, here it goes I am doing some of my first drawings in NX and I have a need to add appended text to a feature parameter that I have pulled in from the model. For example I have a 0.250 DIA hole that goes thru my part. I want to add text that calls the hole out as a press fit. But NX will only let me attach the appended text to the "thru" part of the call out. This looks weird and is very long beacuse the only place to put it is at the end. So, how do I add the appended text to the feature parameter such that it is below the 0.250 DIA portion of the call out?
Hopefully, this make sense
Doug
Doug
RE: Question about editing feature parameter annotation
Believe it if you need it or leave it if you dare. - Robert Hunter
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
I also have another question. Can I change the way NX presents the feature parameter call out. Example, I have a 10-32 threaded hole and the call out looks like this...
10-32 UNF-2B
<deep char> 0.375
I would like all of this on one line without the massive gap between 10-32 and the UNF-2B. Again, I would like to put the # of places call out below this line.
Doug
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
