defining the minimum design metal temperature
How do you define the MDMT (minimum design metal temperature)?
What ambient temperture do you need to be able to define it?absolute minimum? average minimum?
If i have an absolute minimum of 3.9ºF (-15.6ºC), what would the MDMT.
please help me here, i'm dying with this mess!
RE: defining the minimum design metal temperature
If the issue concerns a storage tank, API-650 uses a map of "low one-day mean ambient temperature".  It's the lowest daily average temperature using data from US and Canadian weather bureaus.  NFPA-22 for fire protection tanks also has one.  API use MDMT = Map Temperature plus 15F.  Otherwise, the owner should determine one.
Joe Tank
