PSV for caustic application
Greetings!
I am attempting to find an appropriate means to accommodate PSV relief of a caustic stream (in part steam) from the shell side of a heat exchanger for a fire case (>350 psig).  I can't vent to atmosphere or hot tap into the flare header.  I explored several prospects with upstream and downstream neighboring vessels, but the principle issues arising include incompatible operating parameters leading to continuous nuisance relief, and/or lack of needed vapor space (I can't relieve into liquid).  Can anyone kindly offer comments or suggestions?  Thanks much.
RE: PSV for caustic application
If you can't work with the existing equipment, then you need to either upgrade the existing equipment or install additional new equipment.  Simple as that.
I2I
