Modeling Bend Kink
Modeling Bend Kink
Modeling Bend Kink
Hey guys, I have some square tubing modeled up and bent at some angle.  I need to find out how to show the plastic deformation in the bend.  I've been trying to use the warp tool but haven't gotten anywhere.
RE: Modeling Bend Kink
To get the true shape, you won't be able to do it in Pro/E or even Pro/Mechanica. The warp tool definitely won't do it, as it is primarily a 'cosmetic' tool used for conceptual design, and is not meant to illustrate the true effects of bending something.
Pro/Mechanica does not accurately predict plastic deformations, either (it assumes linear elastic behaviour). In order to simulate something like this, you need to move to a more powerful package like ANSYS or LS-Dyna.
If you have an actual piece of square tube that's been bent in front of you, the best way to do this may be to get out your calipers and use Pro/E's surfacing tools to make a reasonable approximation of the resultant geometry by constructing the bent section from curves and boundary surfaces.
Good luck!
PRuggiero,
In release 2001, there was a feature called "spinal bend".
You could do some nice plastic hinge design with it.
I don't know if this will help.....
Cheers,
JW
