AISI, SAE Conversion for SA-387 Grade 11
Does anyone know of a good conversion material similar to SA-387 Gr 11 in AISI/SAE OR know of someone in the states who supplies this material?
RE: AISI, SAE Conversion for SA-387 Grade 11
There is no SAE equivalent because this is a steel for elevated temperature use.  What quantities do you need?
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
This is an ASME pressure vessel grade of steel plate in the US. You can try Castle Metals or Arcelor Mittal Group.
