Earthing of Transformers
On a standard 11kV/415v distribution transformer, what is the minimum size of earthing conductor required ?
Should it be bare tape, insulated tape, bare stranded conductor or covered stranded conductor ?
RE: Earthing of Transformers
Also from the transformer neutral take out two parallel strips as if there is a fault in one then atleast there is one to take care of the earthing. Also with parallel conductors the effective resisitance is always low.
hope you find this usefull if you give further details then other data can also be given.
regards
gautam
