CADKEY to Solidworks migration
I am working on a project for migrating CADKEY fles to solidworks. I am using CADKEY 98.
I have some questions. Any help is highly appriciated.
1. I have 2 file types (.PRT & .CKD). I am able to open the PRT files but I am unable to open CKD files.
Questions:
1a. what is the use of each of these file types?
1b. Am I missing any modules to be using with CADKEY?
2. On opening the PRT files I can see that these are 2D drawings on the layout space. I strongly believe these are created from 3D models from the look of it. But when I try to go to model space by clicking LAYOUT and EXIT, there is no 3D model present. Instead, a new Layout dialog appears.
Questions:
2a. Where is the 3D data stored?
2b. How can I get a Iges of the 3D data?
2c. Also is there any way to identify if the model is wireframe or solid.
PS: I am a core SolidWorks user. Questions might be basic. All help is highly appreciated.
Questions:
Questions:
RE: CADKEY to Solidworks migration
If you can send me the files I may be able to translate them into something you can use. I'm not sure how to show my email address on this forum however.
Solidworks will import both PRT and CKD files.
It is possible that there is no 3D model associated with the 2D's in layout. One place I worked we used to do 2D prints in layout mode (no 3D model) as it was easier to import drawing borders.
Levels can be accessed through 'View-Levels-List'.
Hope this helps.
