[b]SUPPLY DUCT LOOPS[/b]
I've seen many base building projects where the main building design has VAV rooftop units and the supply distribution on each floor has the supply duct in a continuous loop around the floor. The return is a plenum return system.
Can somebody tell me what the reasoning is for designing the supply duct in a continuous loop like this. How do you figure airflow rates when trying to size the ductwork?
Thanks for your help.
RE: [b]SUPPLY DUCT LOOPS[/b]
