A shell rolled in the "wrong" direction
A vessel has been fabricated in a way that its axis is parallel to the mill rolling direction of the plate - like a pipe. It has a small diameter ( 550 mm ) and thick wall ( 32 mm ).
Is that acceptable, to ASME code?
RE: A shell rolled in the "wrong" direction
The only references to rolling direction I've seen to rolling direction was in some working with stress concentration as it pertains to fatigue.
It was convention to report the lowest values for a metal's physicals based on which direction gave the values, longitudinal or traverse.
Now I know yhat I didn't miss some hard-to-find footnote or interpretation.
Thank you.
