Unified Thread Standard Question
Will a female connection having a 4" 8UN thread (per ASME B1.1-1989) screw on to a 4" NPT pipe nipple?
S. Bush
www.water-eg.com
RE: Unified Thread Standard Question
You will need to find Nps-3.5 pipe (4.0 inch od.) to thread and fit into the 4-UN thread. It will not be leak tight, so a flange + gasket, or a counterbore + O-ring seal would be needed for pressure tight joint.
