Can this be done in Solidworks?
I have this drawing of a part I need to make a solid model of in SolidWorks. I have the revolved feature completed but I am not sure if Solidworks can make the swept features on the sides of the part how they need to be done. If anyone could help me out I would appreciate it.
Thank you,
JT
Thank you,
JT
RE: Can this be done in Solidworks?
I see you posted the same question in the SW and ProE forums. Are you trying to evaluate the software? If so, get your VAR to do it.
-handleman, CSWP (The new, easy test)
Not all of us work in SW 2008.
Dan
www.eltronresearch.com
handleman
Actually I have a couple of different software packages I can use to do this. I am just trying to find out which it would be easier to do in.
