What is 1D/System CFD?
When explaining what 1D CFD or System CFD is , i struggle to define it clearly.
1D software include Pipeflow, Olga, Wanda and Flowmaster
Does anyone have a good description technically and in Layman terms to describe this type of analysis?
Thank you in advance
RE: What is 1D/System CFD?
2D down the pipe plus considering (turbulent) flows in the wall to pipe centerline direction, or flow around an aircraft wing x-section.
3D flow around a wing x-section plus perpendicular wing tip vorticies in the wing tip to fuselage direction.
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
