Attn: MadMango
Attn: MadMango
Attn: MadMango
As referenced elsewhere, here are two macros that may help you out.  The first one de-selects the last-selected item of the current selection set and instead selects the parent subassembly of that component.  It's basically the same as the "Select Sub-Assembly" in the RMB menu, except it's easier create large selection sets.  The RMB menu command brings up a popup box for you to select the level.  This macro just goes up one level.  However, if you immediately run it again it will go up another level.  I've posted this one before, but I figured I'd go ahead and put it in again for convenience.
The second macro will de-select the last-selected subassembly and instead add all its children (including those in pattern features) to the current selection set. If the last thing selected was not a subassembly it will just give a message and not change the current selections.
I use the first one hundreds of times per day.  It works great when mapped to a shortcut key.
CODE
' Macro to select parent assembly of the selected assembly component
' for easy mating.  Modified extensively from the
' "Select Origin of Assembly Component Example (VB)" in
' SolidWorks and Add-Ins API Help
' Preconditions:
'       (1) Assembly document is open.
'       (2) One or more items is selected.
' Postconditions: The parent subassembly is selected.  Will not select
'the top level assembly.
Option Explicit
Sub main()
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swSelMgr                    As SldWorks.SelectionMgr
    Dim swSelComp                   As SldWorks.Component2
    Dim bRet                        As Boolean
    Dim GeneralSelObj               As Object
    Dim i                           As Integer
    Dim CurSelCount                 As Long
    Dim NewObjToSelect              As Object
    Dim swVer                       As Variant
    Dim ResolveIt                   As Integer
    Dim DocTitle                    As String
    Dim DwgDocComp                  As DrawingComponent
    Dim OldToggleVal                As Long
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    If swModel.GetType = swDocPART Then
        MsgBox "This macro works on assembly documents or assembly drawings only."
        Exit Sub
    ElseIf (swModel.GetType = swDocDRAWING) Then
        If (swModel.ActiveDrawingView.ReferencedDocument.GetType = swDocPART) Then
            Exit Sub
        End If
    End If
    Set swSelMgr = swModel.SelectionManager
    CurSelCount = swSelMgr.GetSelectedObjectCount
    If CurSelCount = 0 Then
        MsgBox "Nothing was selected"
        Exit Sub
    End If
    Set GeneralSelObj = swSelMgr.GetSelectedObject(CurSelCount)
    If swModel.GetType = swDocDRAWING Then
        Set DwgDocComp = swSelMgr.GetSelectedObjectsComponent2(CurSelCount)
        Set swSelComp = DwgDocComp.Component
    Else
        Set swSelComp = swSelMgr.GetSelectedObjectsComponent(CurSelCount)
    End If
    swVer = Split(swApp.RevisionNumber, ".")
    If CInt(swVer(0)) < 14 Then
        If swSelComp.GetSuppression <> swComponentFullyResolved Then
            If swSelComp.GetSuppression <> swComponentResolved Then
                ResolveIt = MsgBox("The component selected is not fully resolved." _
                   & vbCrLf & "This functionality is only available for lightweight" & vbCrLf & _
                   "components in SolidWorks 2006 or greater." & vbCrLf & vbCrLf & _
                   "Resolve this component now?", vbYesNo, "Upgrade Time!")
                If vbYes = ResolveIt Then
                    swSelComp.SetSuppression2 swComponentFullyResolved
                Else
                    Exit Sub
                End If
            End If
        End If
    End If
    Set NewObjToSelect = swSelComp.GetParent
    If Not NewObjToSelect Is Nothing Then
        swSelMgr.DeSelect CurSelCount
            Set NewObjToSelect = NewObjToSelect.GetDrawingComponent(swSelMgr.GetSelectedObject6(swSelMgr.GetSelectedObjectCount2(-1), -1))
            swModel.ClearSelection2 True
            OldToggleVal = swApp.GetUserPreferenceToggle(swAutoShowPropertyManager)
            swApp.SetUserPreferenceToggle swAutoShowPropertyManager, False
            bRet = NewObjToSelect.Select(True, Nothing)
            swApp.SetUserPreferenceToggle swAutoShowPropertyManager, OldToggleVal
        Else
            bRet = NewObjToSelect.Select(True)
        End If
        'Debug.Print bRet
    End If
End Sub
CODE
Dim swDoc As SldWorks.ModelDoc2
Dim swAssy As SldWorks.AssemblyDoc
Dim SelComp As SldWorks.Component2
Sub main()
Set swDoc = swApp.ActiveDoc
If swDoc.GetType <> swDocASSEMBLY Then
    Exit Sub
End If
Set swAssy = swDoc
Set swSelMgr = swDoc.SelectionManager
On Error GoTo HANDLER
Set SelComp = swSelMgr.GetSelectedObject6(swSelMgr.GetSelectedObjectCount2(-1), -1)
On Error GoTo 0
swSelMgr.DeSelect swSelMgr.GetSelectedObjectCount2(-1)
AddChildrenToSelectionSet SelComp
HANDLER:
If Err.Number <> 0 Then
    MsgBox "An error occurred.  Your selection may not be a subassembly."
End If
Set SelComp = Nothing
Set swAssy = Nothing
Set swSelMgr = Nothing
Set swApp = Nothing
End Sub
Private Sub AddChildrenToSelectionSet(ByVal myComp As SldWorks.Component2)
Dim ChildArray As Variant
Dim i As Long
ChildArray = myComp.GetChildren
If Not IsNull(ChildArray) Then
    For i = 0 To UBound(ChildArray)
        ChildArray(i).Select True
        AddChildrenToSelectionSet ChildArray(i)
    Next i
End If
End Sub
-handleman, CSWP (The new, easy test)
RE: Attn: MadMango
Thanks!  I can see myself using that 2nd Macro for sure.
This is in response to a complaint I had about using the Cavity feature, and having to select Parts only, not subassys.  This will come in handy when I am potting circuit boards in missile components.
...now if I could only select circular/linear patterns without having to expand them!
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: Attn: MadMango
Oops, lemme try again.  I've never used the cavity feature, so  I thought I'd give it a go.  In trying it out, I realized that as-posted, the macro doesn't un-select the subassemblies it selects.  So I fixed that.  Then I found that the Cavity feature doesn't like it when you select suppressed components.  So I put a flag constant at the top that controls whether or not suppressed components are selected.  Not sure why one would want to select them, but I left the option open.
CODE
Const SELECTSUPPRESSED As Boolean = False
Sub main()
    Exit Sub
End If
Set swAssy = swDoc
On Error GoTo 0
HANDLER:
End If
Set swApp = Nothing
End Sub
Dim i As Long
If UBound(ChildArray) > -1 Then
        If ChildArray(i).GetSuppression = swComponentSuppressed Then
            If SELECTSUPPRESSED Then
            End If
        Else
        End If
    Next i
End If
End Sub
RE: Attn: MadMango
After a bit of modification, this will now do both subassemblies and patterns.  Any selection other than a subassembly or a pattern feature is ignored.  Enjoy!
CODE
Dim swSel As SldWorks.SelectionMgr
Dim swFeat As SldWorks.Feature
Dim PtnChild As Variant
Sub main()
Dim i As Long
Dim swPtnComp As SldWorks.Component2
Dim mySelType As Long
    Exit Sub
End If
Set swAssy = swDoc
Set swSel = swDoc.SelectionManager
Select Case swSel.GetSelectedObjectType3(swSel.GetSelectedObjectCount2(-1), -1)
    Case swSelCOMPPATTERN
        Set swFeat = swSel.GetSelectedObject6(swSel.GetSelectedObjectCount2(-1), -1)
        swSel.DeSelect swSel.GetSelectedObjectCount2(-1)
        PtnChild = swFeat.GetChildren
        For i = 0 To UBound(PtnChild)
            Set swPtnComp = PtnChild(i).GetSpecificFeature
            If (swPtnComp.GetSuppression = swComponentSuppressed) Then
                    swPtnComp.Select True
                End If
            Else
            End If
            AddChildrenToSelectionSet swPtnComp
        Next i
    Case swSelCOMPONENTS
        Set swPtnComp = swSel.GetSelectedObject6(swSel.GetSelectedObjectCount2(-1), -1)
End Select
Debug.Print swSel.GetSelectedObjectCount2(-1)
Set swPtnComp = Nothing
Set swSel = Nothing
Set swDoc = Nothing
Set swApp = Nothing
End Sub
Dim i As Long
            End If
        Else
        End If
    Next i
End If
End Sub
RE: Attn: MadMango
Thanks again, I haven't had a chance to try it out, but I will soon.
RE: Attn: MadMango
handleman,
A star for you. This is just what I needed. I have not tried it yet, but I will. Thank you.
Bradley
SolidWorks Pro 2008 x64, SP3.0
PDMWorks Workgroup, SolidWorks BOM,
Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB,
nVidia Quadro FX 3400
Use SolidWorks BOM
e-mail is Lotus Notes
