Un-highlighting model/edges
Hello all,
(I use Pro/E Wildfire 2.0)
In drawing mode, when I select "View" then "Drawing Display" then "Edge Display", I get a pop-up menu. On the pop-up menu there is a selection "Highlight Mod". When I select that there are certain edges that become highlighted (they turn bold blue).
My problem is that I've not seen any selection that allows me to un-highlight the model/edges. What I've been doing to redraw the views without the highlighted edges is to save the drawing then erase it from session then bring it back up again. Is this weird? Am I overlooking something that is incredibly obvious, but just can see it?
Thank you in advance for your assistance.
SrGilberto
SrGilberto
RE: Un-highlighting model/edges
Left click a view whose modified edges have been highlighted, then go to edit > properties. If the view is a general view and has no parent views, then in the category labeled "view type" there are options to change the view orientation. If you choose the "angles" method then cancel before applying any changes, the highlighted edges become unhighlighted.
If the view is not a general view and is dependent on another view, follow the above procedure on the general view that it's dependent on.
This is a silly process, but I guess it beats saving and reopening.
