PWHT per B31.1
PWHT per B31.1
Welding a F91 6000# Weldolet to a 14" Sch 160 P91 pipe requires PWHT - True or False?
RE: PWHT per B31.1
RE: PWHT per B31.1
thanks for your support, I have a boss who keeps arguing with me that PWHT should be calculated on weld thickness not material thickness.........this argument is more to do with welding P4 materials.
RE: PWHT per B31.1
I don't have a current copy of B31.1 handy, but, your boss would be right by the '92 edition.
RE: PWHT per B31.1
Using older editions of any Code to skirt the issue regarding PWHT is not wise because Grade 91 was not endorsed by B31.1 at that time.
New materials that are used in construction must be understood as to their use. Using an excuse like an older edition of the code to skirt the issue of PWHT, especially for Grade 91 material, might work as a loop hole for some but to me this is technically unacceptable and plain irresponsible.
RE: PWHT per B31.1
I think it would be beneficial for you and your boss to read the following pdf.
http://www.psimedia.info/Industry%20Alert.pdf
If your are to follow the/a code it has been my understanding that if it's new construction you have to use the latest incarnation.
RE: PWHT per B31.1
Your comment is duly noted, however, I was not suggesting that using an out of date Code book is an acceptable practice, nor was I taking issue with your comment regarding the necessity for PWHT on P91, I was merely pointing out that, at least in the '92 ed. of B31.1, weld thickness was the governing factor for determining PWHT soak times. This is the case in other Codes such as Sec VIII, but, I find many people fail to grasp this point. Of course, Code rules are minimum requirements, and other factors may need to be considered when determining approprite soak times for PWHT.
RE: PWHT per B31.1
