Clogged water filter from pump outage?
Yesterday the termite inspector accidentally shut off my water pump. I got home from work, had no water, looked, found it, turned it back on; but now I find my filters on the water line at the sink are clogged with sediment. Can anyone explain why turning off the pump should stir up sediment from somewhere? After all, the pump goes off and on several times a day, as we draw water from the pressure tank, doesn't it?
The best, admittedly lame, explanation I can think of is that there is sediment in the pressure tank, that ordinarily isn't disturbed because as soon as water is drawn, the pump comes on and refills the tank; but since the pump was turned off, the tank got much lower than usual, until the pressure was zero; and that drew up water from the bottom. Can someone do better?
RE: Clogged water filter from pump outage?
Steve
