Help with AutoCAD DWGs and designating zones
Hello, I'm a software developer who's recently been thrown in the world of AutoCAD for a project where we extract device information from CAD DWGs our Engineers produce.
I'm hoping someone can point me in the right direction here, I'm looking for some information on how to extract and/or specify zone information within a drawing, if it's even possible. For example, my hope if that our engineers can designate some type of zone within which a block is contained that could correspond to geographical information within a building, for example a room may be contained within a floor, which is contained within a building. I'd like to be able to extract a location hierarchy from this information, i.e. Building X->Floor 5->Room 123->Block X from a single drawing without having the engineer type this information for each block.
I hope that this is not too vague. I've been successful in extracting attribute information from blocks, I'm just not sure how a drawing should be setup to be able to setup a hierarchy like this to traverse for location information. I certainly appreciate any help anyone can provide.
Thanks! - Will
Thanks! - Will
RE: Help with AutoCAD DWGs and designating zones
You could develop a program that simplifies the block insertion and auto populates some attribute information, or the user could select from drop down menu's.
Other than that, if the blocks were contained within closed polylines then it would be possible but you would still need some additional information contained within the polylines
and I am just thinking out loud after reading hendie post.
At the end of the project, one guy could just boundary off each rooms with polygons and name them that polygon. Then extract the polygons and blocks, compare the points to locate the room.
This way you wouldn't have to edit each block and they could copy, move, and stretch all they want while they are building the drawings up.
Zuccus.
http://
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
Thanks again. -Will
Don Phillips
http://worthingtonengineering.com
