5/8" O.D. tubing, is it normal?
is it normal to order a tubular heat exchanger with 5/8" O.D. tubings in the US? Do the vendors have to procure them specially so that this will make more cost than ordering a heat exchanger with 3/4" tubings?
Thank you in advance.
RE: 5/8" O.D. tubing, is it normal?
There is no harm in ordering HX with tube OD 5/8". It is a regular size so no such cost impact.
We often order 5/8" tubes in lieu of 3/4" where tube velocity or design criteria is an issue....no problem and no delivery impact.
MartinSS
I can't say how "normal" it is, but I have come across more than a few heat exchangers with 5/8" tubes.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
