Section view û hole/shaft thread overlap
In section view the threaded sections overlap between a hole and a shaft. I have made the edges hidden (the internal edge of the hole, displayed „inside" the shaft), but the two hatches are still overlapping. How to display the threaded section properly? Any workarounds?
Let me know, if I'm not clear on the subject. In that case I'll attach a file.
Gabor
Gabor
RE: Section view û hole/shaft thread overlap
-handleman, CSWP (The new, easy test)
I'd rather try to fix the drawing itself, keeping the models intact.
I tried to modify the drawing view, but the hatch seems to be unified, no possibility to erase just a part of it.
Dan
www.eltronresearch.com
Thanks for the posts.
