Sectioning a Part
Sectioning a Part
Sectioning a Part
When I section an End View from TDC to 4 oclock say, I get a Solid Horizontal Line across my section view where a center line should be.
In the SE v11 User Guide pg 374 the example shows what I want to do but this has a end view like I want and expected.
If I section from TDC to BDC its OK - I can then "Draw in View" and put a centerline in
Any suggestions
TIA
Milkboy
RE: Sectioning a Part
I don't know if this is the "right" way to solve this, but it is the only way I know how.
When you go to draw in view of the section you created you should have a toolbar button called hide edges.  I click this then select the line I want to get rid of.  I then return to draft and place the center line.
I have had to on occasion re-hatch in view after removing a line, but that was the only problem I had.
Magic
Cheers James
Milkboy
