Condensate Flow meters
Are there any options out there to measure condensate flow without needing back pressure as is the case with a turbine meter?
RE: Condensate Flow meters
JMW
www.ViscoAnalyser.com
Yes you'r right if the liquid is near the flash point it may flash.
I have had trouble with liquid Chlorine well below the flash point flashing in both Coreolis and Vortex meters.
I put it down to the additional mechanical energy imparted bu the vibrating tube or vortexing.
Roy
