How can I have 1:1 print?
I am new user of Solid Edge. I have SE version 19. My work requires to draw simple 2D drawings, which I can draw easily on Solid Edge sheets. I can print the current display or print area from sheets, which are obviously not according to the true scale of physical items.
I need to know how can I print my 2-D drawings on 1:1 scale?
RE: How can I have 1:1 print?
You can then pick the appropriate sheet size format, create the appropriate views at 1:1 (or other scales as need be) and dimension there.
Basically it allows you to create views from 2D information, not just 3D model.
If you literally just need a 1:1 printout of a sketch do print area, when the box comes up set paper length equal to design length (i.e. to 1). This will then print out the selected area 1:1. I can't remember what it does if the design area is too big for the paper selected.
KENAT, probably the least qualified checker you'll ever meet...
I got it, it works for smaller geometry on letter size paper on standard printer and I suppose it will work too on plotter for larger geometry.
