Question concerning this elec. Riser diagram.
Good Afternoon,
This is my first attempt at a riser diagram for a small office.
Can Any tell me what wrong with my riser diagram? This will be applied to a small building with one commercial space on the ground floor with two apartment on the second floor. The total load needed for each is 125Amps per, unit. in order to calculate my lighting and receptacles, I used the "receptacles and light @ 3w/sqft. method" Where can i find more information on how to do calculation the different equipment/appliances for the commercial space?
Though i included my lighting in the above 3w/sqft. calculation,does this need to be, if these are continuous loads? Do i need to show and pipe/wire sizes to this riser dia?
RE: Question concerning this elec. Riser diagram.
The IEEE Grey book covers commercial building electrical design.
BTW, you didn't provide a link to a riser diagram, at least that I can see.
Don Phillips
http://worthingtonengineering.com
