STAAD Question
STAAD Question
I am trying to model the bending effects of self weight in a column section, subject to an initial deflection at mid-height, and doing a p-delta analysis. The initial deflection is required because otherwise, there would be no bending. Does anybody know how you would do this in STAAD?
RE: STAAD Question
RE: STAAD Question
I must be doing something wrong, because when I do what you're telling me, I get a warning that says "support displacement in released direction ignored".
RE: STAAD Question
I could be wrong here, but STAAD only does first order analyses and the type of P-Delta analysis that it runs won't work in this situation as a second order analysis.
RE: STAAD Question
