Fuse TCC depends on voltage?
Does Fuse TCC depends on system voltage?
i.e. is it possible to have diff. Time current characteristic (curve) for a fuse if used at different system voltages (like 2.4kV or 5.5kV)?
RE: Fuse TCC depends on voltage?
There can be slight differences based on the voltage class of the fuse.  There should not be much difference between 2400 V and 5500 V normally.  The manufacturer's fuse curves should indicate the applicable voltages.  This is probably more of the case for currrent-limiting fuses as opposed to expulsion fuses.
