Cut away part of component in drawing view
I'm trying to cut away a corner of a component in one of my drawing views in order to show what is underneath. I can't find a command that sounds like it does this but I'm sure there must be one.
Does someone have any suggestions?
PESOA
PESOA
RE: Cut away part of component in drawing view
Dan
www.eltronresearch.com
-handleman, CSWP (The new, easy test)
Thanks. I found the command staring me in the face.
I haven't gotten it to work yet though. I tried creating a closed spline and then picking the component that I don't want to show. Then I've tried several depths but none seem to make a difference.
When I've finished, the broken-out section shows in the feature manager but not in the view.
Have you run into this?
PESOA
Which graphics card and driver?
Did you try Ctrl Q to force rebuild?
Example, you want a broken out section of the rear wheel/tire of a typical bicycle (side view). You first think, you would set the depth to approx 1/2" because that will go half way through the wheel. But you forget that the handlebars are "coming out of the page" about 12". You need to set your depth to 12.5" to get what you desire.
Hope that make sense... try deeper distances.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Thanks, the depth was the problem. I was trying to keep it small. I'm actually in a plan view.
PESOA
