Inventor 2009 and Workbench 11.0 sp1
Dear All
Are there Interface problems using Inventor 2009 and Workbench 11.0 sp1?
This is officially not supported by ANSYS but usely it still works. The 32-bit version of Inventor with 32-bit Workbench still works, but when Inventor becomes 64-bit the interface is killed.
Who is facing the same problem(s)?
Are there know workarounds?
Garry
Garry
RE: Inventor 2009 and Workbench 11.0 sp1
Anyone???????
Garry
It's just that I want to know how many of you are facing the same problem. And if they know a wrokaround to fix the problem for the interface. Because exporting sat from Inventor is a good workaround to get the geometry in Workbench, but then the bi-directional associativity is gone. Iges and step can't be imported to workbench on a 64bit.
Thanks for the reply.
Garry
