Annotations with double leaders?
Yet another how do I do this... I want to make one annotation but have it point to two places with 2 leaders.. Seems this should be simple but the solution evades me. The "help" shows a picture of such a feat but does not explain how to do this.
RE: Annotations with double leaders?
To add new leaders to an existing dimension or hole callout:
Select the dimension or hole callout.
Hold down Ctrl and move the pointer over the square handle as shown.
The pointer changes to
Drag the arrow head to another entity of equal size.
Drop the arrow head on the new entity and release Ctrl.
-handleman, CSWP (The new, easy test)
- or -
RMB on an existing leader and select Insert new branch, then select an entity.
- or -
When placing a new annotation, hold down the Ctrl key when selecting the entities.
cheers
Thanks... I knew there had to be a way..
You mean all this time of creating multiple text annotations with no text just to get extra arrows was a waste of time!!!!!
