Looking to find who makes this specific flame scanner/viewing head
I've just started working at a company and I got given this UV burner flame scanner and told to find out who else makes them. I know Hamworthy does but is there anyone else? Hamworthy is being really uncooperative and we're going to go into shutdown mode soon if I can't source this part.
Any help would be greatly appreciated!
RE: Looking to find who makes this specific flame scanner/viewing head
Scanner will only be as useful as the amplifier circuit that it mates with.  For instance, Honeywell makse UV flame scanners, but they must be mated with the proper amplfier (sometimes integral to the flame safeguard control).
I guess what I am saying is that if you change the scanner, you will likely have to change the main control it interfaces with as well.
Fireye makes a good reliable flame management system.
Like Lownox said though, most likely there will be additional changes than just changing the scanner element most likely your entire control system will be effected.
