out-of-range velocities
Dear all,
I'm simulating an impact test using ansys/ls-dyna, when I change an imput data  "out-of-range velocities" error appears: for example,since  I tried to insert the following soil  and gravity datas
N,300000 ,8000,0,50,,,,
N, 300001,8000,0,7000,,,,
N,300002 ,-17000,0,7000,,,,
N,300003 ,-17000,0,50,,,,
EDMP,RIGI,5,7,7
MP,DENS,5,1.57e-7
MP,EX,5,200e3
MP,NUXY,5,0.33
TYPE,   2
MAT,       5
REAL,       1
ESYS,       0
SECNUM,
FLST,2,4,1
FITEM,2,300001
FITEM,2,300000
FITEM,2,300003
FITEM,2,300002
E,P51X
ESEL,S, , ,   12248
NSLE,S
CM,suolo,NODE
NPLOT
ALLSEL,ALL
ASEL,S, , ,       1
NSLA,S,1
CM,surfsoil,NODE
NPLOT
ALLSEL,ALL
*DIM,TIME,ARRAY,2,1,1, , ,
*SET,TIME(2,1,1) , 1
*DIM,gravity,ARRAY,2,1,1, , ,
*SET,gravity(1,1,1) , -8820000
*SET,gravity(2,1,1) , -8820000
!gravity
EDLOAD,ADD,RBFY,0,8,TIME,gravity, 0, , , , ,
!contact
EDCGEN,STS,surfsoil,soil,0,0,0,0,0, , , , ,0,10000000,0,0
my model goes in instability:
"node #  ... has out-of-range velocities"
Is there a certain reason why instability appears?
I tried to semplify my model, but I obtained no results
Is there literature about this problem? Is it contained in ansys help?
Oh I forgot... if possible, I'd like to maintain initial velocity for impacting body (20-30 Km/h) , target body thickness and mat prop (steel, 5mm)
tnx to all for attention, regards
RE: out-of-range velocities
Can it be a coarse mesh problem?
