Shear force on a bolt
What are the shear forces on a bolt connecting a strut to a concrete floor? The strut is supporting a flight header for a stair platform and another strut supports the platform header.
RE: Shear force on a bolt
But if the strut has any other members connected to it internally, between its two ends, the strut would also be a beam, having internal, beam shear forces, and the answer would be more complicated than the above.
...you are subjecting your bolt to shear, which is the force you exert ...
Keep the wheels on the ground
Bob
showshine@aol.com
The shear strength of a fastener may be given as a percent (e.g. shear strength = 60% of tensile strength), but the question relates to applied shear stress. It makes no sense to relate this to the fastener's tensile strength.
Where a strut goes down to a ground-floor slab, consideration should be given to the possibility of an impact from a passing vehicle. Depending on the use of the building, there is a possibility of corrosion as dust collects round the base of the column. I would always have 2/M16 or 5/8" bolts.
Russell Keays
